Ok, first off the bat, I'm gonna remove the Viscous fan, and install an electric one... just thinking how do I wire it up, to the temp switch ? If I buy a fan should it come with a plug ? and also what size fan ?
2nd, I want to do a big brake conversion, was thinking of using 330i calipers and 300mm disks (also I heard that E39 528i brake calipers r the same ? can anyone confirm) ... was thinking it shouldn't be to hard, just a bracket 2 offset the caliper ?
3rd, I'm gonna wire a switch 2 my fuel pump 2 turn it off, and on... Viable ? thought it would make a good safety thing, turn it off and u can't start the car...
4th, I'm gonna run standalone management, cause to get a chip is gonna cost just as much, and then I don't have 2 do the MAF conversion, I can just run a MAP sensor... and be finished. Was just thinkin what features I should look into having on the management ?
I was thinking of running a local system www.mrturbo.co.za ? what u guys think ?
Steve
A few things I've been thinking of doing ?
OllieB
Apparently a good electric fan to use is one off an escort RS Turbo, not sure if you have them over in SA though....
I'm too scared to drift properly......
Stevin
Only got like 5 of them here
Stevin
BUMP
