help please
andy325
Post Tue Feb 28, 2006 12:02 am
my car starts ok when its cold but is getting harder to start when warm and seams to be getting worse.
the engine turns over ok but just takes a while to fire up.
the blue and brown temp sensors were changed last summer.
the co is correct
my car is a 325 mtech sport pre-face lift fitted with bbtb, itg air filter and high lift cam.
hopefully someone can shed some light on my problem for me.
thanks in advance
andy
kam-325i
Post Tue Feb 28, 2006 12:04 am
9/10 times this sort of problem is caused by a bad blue temp sensor or wiring for the sensor....
andy325
Post Tue Feb 28, 2006 12:07 am
is this likely as the one fitted is not a year old yet.
it was brought from ecp -- should i be buying one from a main dealer??
Post Tue Feb 28, 2006 1:01 am
Check out the plug and socket for the injectors under the inlet manifold. Brown and blue sensor wiring goes through this.
andy325
Post Sat Mar 04, 2006 1:08 am
thanks for the advice brian but i could find a wiring connector under my inlet manifold
my car is a pre-facelift 325 sport should there be a plug there?
