and whats the difference in these conversions . im stuck in my new choice of car . as i want 2.7 or 2.8 to be the main aim . but where should i start . i have btb manifold ,ecu and shocks to replace standard
im just stuck to wat need to be done.
Only thing you want off the e is the bottom end.psychochild187 wrote:thats what i thought about. im after the touring . its that rear disk im after too not worried about elecy this or that but will like obc for lap times and i have a lsd but guess the 320 is small case diff and pro so need some bits and bobs from 325
project mix n match .
would i get all the throttle bodys and inlets off the 2.5e engine for the conversion?
