Bail! Bail! - We're taking water captain!! (325 Touring)
Morat
Post Fri Feb 17, 2006 11:22 am
I just checked out the left side boot compartment because I was looking for a place to stow a warning triangle I've got off ebay... and... it had about 2 inches of water sloshing round the bottom. It looked clean, and I mopped it out with a handy towel but I don't think this can be good news overall.
Is this all to do with the rear wash wipe? The pipes _look_ intact but I don't get any squirty action when I press the button - just the wiper moving around. Is there a prime suspect in the pipery that goes on in there or should I just pull the lot out and go over it with a fine toothed comb? Any links to handy hints would be a godsend.
Morat
klu99apm
Post Fri Feb 17, 2006 11:28 am
I had the same problem on my tourer and it was the seals on the rear light cluster.
I just used silicone sealant and that seems to have fixed the problem.
(Doesn't explain your lack of squirty action of course!)
dbanbery
Post Fri Feb 17, 2006 12:19 pm
You could also get replacement cluster seals.... i suggested sealant a few months back to someone with same problem and got bombed by Scott. LOL
Gwynleym10
Post Fri Feb 17, 2006 1:06 pm
Yes new cluster seals only cost Ԛ£8 from the dealer.
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
Morat
Post Fri Feb 17, 2006 2:20 pm
Right then, I'll check the rear cluster for leaks. I'm assuming that there will be damp in there somewhere if thats where the water is coming in.
In the meantime UP PERISCOPE!!
Morat
dbanbery
Post Fri Feb 17, 2006 3:11 pm
you be watching out for pirates fellow cabin boy!
316eyes
Post Sat Feb 18, 2006 12:16 am
When your'e mopping up - don't bend over if the bosun is around.
:hump: :hump: :hump:
