BRAKE LIGHT WARNING PROBLEM?
geordiestallion
Post Tue Feb 14, 2006 3:44 pm
Can anyone give me a clue about my brake wear indicator light??
it seems to come on and off while im driving, ive checked me pads n theyre fine and cant seem to find a loose connection either!! any tips or hints as to what to try next?? Maybe i will just disconnect it altogether!!
that should fix the blighter!! :twisted: :twisted: :twisted:
Cava
Post Tue Feb 14, 2006 7:48 pm
Check that the front and rear sensors (if you have rear discs) are sitting in the guides and that the leads are in the little clips. You'll never believe how sensitive the connections are - get someone to watch the dash while you push on the connectors and you'll see. Worts case scenario would be to try a new lead - they are about Ԛ£3 from ecp or bmw.
Post Tue Feb 14, 2006 9:35 pm
Use the forum search button above, and search for "220 ohm resistor" and my username. Very, very common problem.
