Check panel brake
DazzyA
Post Mon Feb 13, 2006 5:48 pm
Has been on since I bought the car. Had a look today and the rear LED spoiler is wired to the chassis and the other wire is wound around the bottom(male pin) of the rear light cluster connector (drivers side 2nd from right). When I played with the connector at the brake pedal it went off for a little while when it was wound out fully, but light came on again not long after. Where should the spoiler be wired to and have I got a dodgy brake switch thingy??
Pass me the spanner
