M20 6 Speed (Gs6-17bg)
10hldh
Post Wed Jun 17, 2026 5:18 pm
Hi all,
My brother recently purchased an 86 320i, the car is a factory auto and we’re looking at manual swapping the car.
I’ve currently got a gs6-17bg from an e90 sat in my garage with a clutch and flywheel that was previously mounted on an M5x.
Is there any reason this shouldn’t work on the m20?
I know it’ll need an offset gearbox mount as it’ll sit at 10°(?) off centre.
Is there anyone out there already running this box?
If so what prop are you using?
Any help/advice would be appreciated.
Cheers, Luke
85 318i 3Dr (M20b25)
Probably more rust than the titanic!
70 MGB GT V8 project
Just as much rust
13 F31 320d
The practical one
Post Mon Jun 22, 2026 10:47 pm
I suspect it can be done if you're determined enough! I'd be interested to learn more about your 1970 MGB GT V8 project...
Post Wed Jun 24, 2026 7:53 pm
320d box is the same angle as an M20 although the gear ratios are not as favourable
