Hi for some reason the previous over has been and cut a couple of connectors off the loom.
The first one I need is the heater temp control flat white connector plus wires green and blue
The second connector is the front brake pad wear the one that’s connected to the loom and has brown and black rubberized wire on it.
David
Heater loom connector and brake pad connector
Snowey
