My e30 320i has a weird idle surging problem and when its warmed it runs super rich.
Ive checked everything and nothing has solved it.
M20b20 idle slightly hunting
BenHar
Try looking through the wiki.
There is a lot of information in there.
Ben
Ben
As above. Interesting to see the AFM in operation as you rev the engine!
I would carefully check all around the inlet manifold and intake area for air leaks - try spraying starting fluid around the various joints to see if the engine revs briefly rise, which would indicate a leak.
Also, which ECU do you have? Later Motronic 0 261 200 380/381 versions had extra diodes in the idle control circuit, which are prone to blowing, causing such issues.
Onure30
Just done a smoke test and i can see smoke coming from under and left side of throttle body, to me it seems like the tps, maybe the o ring. Tomorrow im going to have a better look.
Interesting. Did you use a proper smoke machine, or just a fag? ;)
Onure30
Not a fag but a vape actually lolSpeedtouch wrote: ↑Sat Oct 11, 2025 10:12 pmInteresting. Did you use a proper smoke machine, or just a fag? ;)
Haha, good one - must remember that trick!
