E30 325i overheating
SoupAnxiety
Post Sat May 31, 2025 12:58 pm
Hi all,
I have a 1990 E30 325i, owned and cherished for over 12 years. It's had intermittent overheating issues since last summer that have been investigated and fixed each time, but the problem recurs. By overheating I mean the coolant temperature shooting up - when this happens I'm stopping the car within seconds and getting it recovered.
Prior to the overheating, it last had belts, a water pump and thermostat for good measure back in June 2023. In August 2024 the overheating started, and as the radiator was crusty it had a new radiator and full coolant system hose kit.
Since putting it back on the road this year, it's had two thermostats. The first was "new" but failed quickly and stuck. In Mid-May it had another thermostat, plus an auxiliary belt as the water pump wasn't being driven properly with a loose belt, plus a coolant flush and it ran perfectly - including multiple trips, days and in stop start traffic.
Yesterday after 20 minutes or so of driving, the coolant temperature shot up in a short queue. I stopped, waited for it to cool and ended up getting recovered. Even when out of traffic the coolant temperature shoots up, and the heater and fans on full puts out hot air but doesn't help when moving. Like previous times, the top hoses were hot, the bottom was cold and the coolant had boiled and vented from the expansion tank.
The oil looks good, and there's no mayo residue like what I found years back when I had the head gasket changed in 2015. There's also no smoke - when it's running fine or when it starts to heat up.
As an aside, there's a mouse nest somewhere in the cabin intake / vents as debris keeps blowing through the vents, and I'm wondering if it could be near the heater matrix and contributing to the problem. I'm clutching at straws but running the fan on hot chucks out heat, but it seems to struggle. Thankfully all electrics work and there's no evidence of them inside the cabin or damage, I just need to work out how to clear out the debris from the vents - and put traps in my garage next winter!
I'm wondering if the water pump could have a tight spot. I'm worried it could be the head gasket on the way out, or a cracked head. I'm stumped as to how the car can be fine sometimes and struggle the next, in similar weather and journey types.
Any ideas would be welcome, and if you need any information on the history of my E30 please let me know.
Post Sat May 31, 2025 5:43 pm
I would suggest following the E30 Wiki guide:
https://www.e30zone.net/e30wiki/index.p ... verheating
I would be inclined to try Steel Seal or K-Seal or similar to hopefully fix it, prior to removing the cylinder head. It may well be the tiniest of cracks causing the problem...
Can the vents not be unclipped? In which case, a decent vacuum cleaner could be used.
SoupAnxiety
Post Sat May 31, 2025 6:35 pm
Thank you!
Assuming the fan is OK, I think clearing the mouse nest from the bulkhead intake (perhaps it's causing a blockage?), changing the water pump then flushing the radiator core are the next steps. The flow could move it around and explain why it's intermittent.
Hopefully it's not the head 🙏
BenHar
Post Sat May 31, 2025 6:54 pm
Does it only do it in slow moving traffic?
If so replace the thermal fan.
Ben
SoupAnxiety
Post Sun Jun 01, 2025 10:21 am
Ben
I think the fan is part of the problem - it runs fine until traffic then shoots up.
Post Sun Jun 01, 2025 10:35 pm
I would suggest performing a test on it as outlined in the Wiki guide:
https://www.e30zone.net/e30wiki/index.p ... ooling#Fan
SoupAnxiety
Post Wed Nov 19, 2025 5:17 pm
Some positive news for an old thread, my E30 is finally back on the road - it was the head gasket. It's been replaced, the head has been skimmed and it's also had a new timing belt, pulleys and water pump.
Runs like a dream now, just in time to go away for the winter!
P.S. The mouse nest was under the fuse box in the engine bay - that's been cleared too.
Post Thu Nov 20, 2025 11:44 pm
Good to hear that, dude. I trust you put in plenty of the correct anti-freeze, to prevent corrosion of the water ways...
rix313
Post Thu Nov 27, 2025 7:35 pm
Great news. Also good job finding the mouse nest, that could have beena nasty suprise come the spring.
