Just picked up a M10 316 carb 4 door.
Obviously the gearbox , selectors, master and slave cylinders with line, flywheel, clutch and prop all require changing but are there any inhibitor switches that need disabling and also will I need to change the diff? Also what gearbox will I need a 240 or 245? It's a 1985 plate
