My TEMP GAUGE doesn’t work, stays on ZERO no matter how long I idle or drive. All other gauges / meters / clock lighting work just fine. It does flicker for half a second when ignition ON then stays still.
Here’s what I’ve tried so far to get it to move:
Tightened nut on back of gauge
Grounded Brown temp sensor plug
Grounded Pin 4 of C101
Tried 2 x other clusters
Next thing to try is probably fit a new temp sensor but I can’t see that solving anything given the above? If it was a rotten C191 plug then Grounding Pin 4 should have worked?
Help much appreciated. Car runs perfect but obvs not keen to go out with a faulty temp gauge…
