M20 overheating!!!!!
ETERNITY
Post Sun May 05, 2024 10:50 pm
My 325i m20 has been overheating when being driven in traffic/idle and my indie has been working on it, temp seems to go halfway when driven and Heaters go hot and cold too
Changed fan clutch, had it bled 3x
Changed thermostat and it had it taken out as it was faulty. Was advised to leave it out for now
Suspected head gasket so Indie told me to leave thermostat out and see how it drives and behaves
Still overheating at idle and traffic, heating hot/cold and temp settles halfway when driving at speed
Water pump?
Head gasket ?
Put thermostat back in
Advice please
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
flybynite
Post Mon May 06, 2024 9:16 am
Putting thermostat back in won't help as you need it open or out if overheating it helps the car warm up quicker.
Before you go pulling the head off -
Who did the bleeding? If they bled it wrong then doing it 3x won't help. Often the nose of the car needs to be well up in the air either on ramps or a hill or both, heater on hot and massage the hoses. Sometimes some cars can be a pig to bleed
Compression test? Leakdown test? oil in water? water in oil? Not 100% guarantee but if they are all good then unlikely the head.
Be tempted to do the water pump and give the engine and rad a good flushing at the same time. If you take the fan and belt off you can sometimes feel if the water pump has too much or too little resistance if you try to spin it. If the rad does not flush with a hose it may be blocked.
These cars come from the days of people putting stuff like radweld in instead of doing a proper repair, blocks the leak and the rest of the system too.
Lots you can do first to diagnose before anything drastic
ETERNITY
Post Mon May 06, 2024 7:57 pm
Yes will do further tests before we strip the head off
Radiator is 7 years old, so it’s in good condition as car is hardly driven. Just weekends and kept inside
My guess is water pump or blocked rad?
Think I need to change indies too
