Hi,
Please quote for the below to fit my 1991 318is
8x Fuel Line Clamp - 1612117705
2x (4pcs total) Hose clamp - 07129952104
1x (6pcs total) Hose clamp - 07129952104
1x (4pcs total) Body Nut - 07129901672
1x (4pcs total) Hex head screw - 07119916966
4x Screw plug - M10X1-ST-ZNS3 - 07119904393
4x Gasket ring - A10X13,5-CU - 07119963072
2x O-ring - D=58,8X4,2 - 16111744369
1x Gasket ring - 16121150391
1x Washer (4pcs total) - 10X5,3X1-200 HV - 07119904206
1x Hex nut (4pcs total) - 07119922038
1x Hose - 16121180402
1x Hose clamp - L32-38 - 07129952115
1x Hose clamp - L42-48 - 07129952119
1x Rubber seal - 16111179680
1x Fuel hose 8X13MM 09/1986 - 16121180409
1x (2 pcs total) Hose clamp L18-24 09/1986 - 07129952109
1x (3pcs total) Hose clamp L=9-12 09/1986 - 07129952102
1x (2pcs total) Hex nut with plate M8 - 51117070183
inc Postage - Thanks, Adrian
318is - Fuel Hose / System parts
adiethirteen
Cotswoldbmw
Hello Adrian
The first part number in your list is missing a digit?
If you can sort that and send me your email address I can send you the cost breakdown.
WIP 59876
Regards
Jon
WIP 59876
Regards
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
adiethirteen
Hi Jon,
Corrected: 8x Fuel Line Clamp - 16121177005
I'll drop you a msg
I'll drop you a msg
Cotswoldbmw
All sorted for you.
Cotswold BMW Parts
01242 335365
01242 335365
