Power window wiring
NMcC
Post Sat Mar 23, 2024 4:16 pm
My window and sunroof switches are illuminated/working all the time when the car is switched off and doors locked is this normal and would it drain the battery?
Contours
Post Sat Mar 23, 2024 5:50 pm
They certainly shouldn't be on all the time so they have got a permanent live feed from somewhere. I have seen a retrofit window kit wired into the central locking circuit which is a permanently live circuit. Anyway, you will have to track it down as it will drain the battery over time.
BenHar
Post Sat Mar 23, 2024 5:57 pm
Check the switches in the door shuts.
There are loads of threads on here about this. Try searching for them.
Ben
Post Sun Apr 14, 2024 5:46 pm
NMcC wrote: ↑
First question: Is this something new that's just started happening, is this a new car to you, or has it always been like this?
Second question: Has anything been done around the starter motor area lately?
Third question: Age and model of E30? There have been relevant changes to the wiring over the years.
