Hi,
The car is a 01/1990 316i Auto with the M40 engine.
I'm trying to track down an issue regarding my engine. It was suggested I replace the earth (grounding) cables. I found the alternator one from BMW and bought it.
I also know that there is another one between the engine and the frame but ETK is driving me crazy as I cannot locate the part number for that specific one. Would anyone happen to know what the part number is for that?
Also am I missing any other earth (grounding) points/cables that I should look into replacing?
Thank you very much!
M40 Earth (Grounding) Cables
DaniTD
I had to replace it some time ago, it was impossible to locate on ETK for the M40 coupe/sedan, but I found it on the touring and it should be the same. I ordered it and replaced with no problem. It's the one that goes from the right side engine mount to the chassis.
Part number 12421737755.
omera60
Thank you very much Dani! It is indeed the one I was looking for.DaniTD wrote: ↑Fri Jan 19, 2024 12:10 pmI had to replace it some time ago, it was impossible to locate on ETK for the M40 coupe/sedan, but I found it on the touring and it should be the same. I ordered it and replaced with no problem. It's the one that goes from the right side engine mount to the chassis.
