Rough idle revs dropping trying to stall when cold
Corasdad
Post Tue Dec 05, 2023 7:41 pm
Please help my car keeps trying to stall but doesn't when I cold start it, the revs sit about 800rpm but flutter up and down, when it's down it trys to stall.
I have cleaned the icv and can feel it vibrate a little so I don't think it's icv,.
I can't hear any air leak but don't know how to test it properly. What else can I test I know it could be a sensor but that's deep in the engine so not sure how to test that.
My engine is m43 with m40 head ( don't know why)
flybynite
Post Tue Dec 05, 2023 8:31 pm
To look for vacuum leaks either do it the correct way with a smoke tester and watch where the smoke gets drawn in or do it the way most people do and spray brake/carb cleaner (sparingly) around the intake, if the revs rise then you have a vacuum leak. Obviously harder when isle is rough.
Otherwise I would check usual suspects, plugs ht leads, air filter and make sure you have clean fuel.
Difficult to be specific as I don't really know 4cyls that well and we don't really know what the engine is wired up as for things like O2 sensor etc.
BenHar
Post Wed Dec 06, 2023 6:11 pm
What year and engine?
Ben
Corasdad
Post Wed Dec 06, 2023 7:38 pm
Car is 1990 no idea what year engine is as somebody has swap it with a frankenstien version b4 I got it
BenHar
Post Thu Dec 07, 2023 6:40 pm
Six cylinder?
Ben
Corasdad
Post Thu Dec 07, 2023 8:40 pm
Na sadly only 4 or mabay even 3 lol
BenHar
Post Fri Dec 08, 2023 6:51 pm
Most likely cause is an air leak on the intake side.
Ben
Corasdad
Post Sun Dec 10, 2023 3:53 pm
Blue sensor changed but still as bad icv cleaned still same 😒
BenHar
Post Sun Dec 10, 2023 6:23 pm
Ben
Corasdad
Post Sun Dec 10, 2023 8:01 pm
Looked at the rubber today all looks good I did notice gasket was broken in manifold have ordered a new hope that works
