After market heated windscreen
Corasdad
Does any body have an after market heated windscreen are they worth the money, my car ices up on the inside all the time when freezing
If it ices up inside that means you have water inside the car that is evaporating and then condensing on the inside of the glass
Corasdad
All my Carpets are dry so I thinks it's just from rain on My clothes
Do a search on here as I am sure this has been talked about.
charlE30
Ricky Evans Motorsport sell them, £290 + postage, I've been looking into them for my track E30 (no heaters).
If you are getting that much condensation in a normal E30 it would indicate there is moister getting in somewhere to be that bad. Blocked sunroof drains or a leak in the boot could do this.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
30316
If as you say it ices up inside then I would say water is definitely coming in from somewhere. Water on clothes normally clears quite quickly once you start driving the car. Check sunroof if you have one and the scuttle area for any rust holes. As said before boot is a possibility as well.
Corasdad
Thanks found a hole in my boot floor
