Hi - in the final stages of restoring my 1983 323i and have most of it sorted, happily using it as a daily driver.
I did some routine maintenance recently and noticed that the lower radiator hose was very poorly routed. First, it is crushed between the top of the alternator and bottom of the air box. It also is directly touching an exposed bolt on the chassis which leaves it prone to puncturing.
I checked the part number on RealOEM and it came up with 11,53-1278925 which matches the number on the hose installed. It just looks so wrong and awkward that there must be a different hose for the 323i.
Any early model experts out there?
323i radiator hoses
flybynite
I don't have my 323i with me as it is in storage but I can check in a few weeks when I go back there but IIRC I never had a problem with the routing of the hoses,
If it is the correct hose and a everything else is as it should be, only thing I can think is it may have been put on backwards. Have you tried to see if it would be better if you swap ends?
BarnfindDan
Thats a good shout. I didn't install it myself. Ill check next weekend when i have some time.
I took some images too which give an idea of what I'm on about.
flybynite
Yup, looks ass about face to me. Worth a tryBarnfindDan wrote: ↑Sat Nov 25, 2023 3:24 pmThats a good shout. I didn't install it myself. Ill check next weekend when i have some time.
hennabm
Hi
Looking at the number it looks like the correct one. It may have been possible to put on the wrong way round. It certainly should not follow the route it is doing. Here are a couple of pictures of my hose.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
