Hi guys
My speedo and rev counter on my cab have stopped working. When i whack the cluster they move abit but still dead after.
I have checked the speedo sensor on the diff and thats fine.
Any idea what i need to do to make them work?
Yaad
Speedo and rev counter
flybynite
If it is not just the speedo, then it is more likely to be an earth problem or a failed solder joint on the back of the cluster. Broken solder joints can be hard to spot.
Needles are quite sensitive and are likely to move when hit. Is there a difference how they move between engine running and everything off. Again likely to be solder joint issue.
If the solder is gone , may be worth finding someone who can solder and has good kit if you are not confident because it is not difficult to make a mess of things.
