Can’t reset service indicator light.
Doobit
Post Mon Aug 28, 2023 10:49 pm
I tried to reset the service indicator light using the usual wire trick but this time it didn’t work. I think this means the SI battery is knackered, is this correct? And is replacing the battery as much of a bastard as it sounds?
E30 325i Cabriolet Alpinweiß chromie
F12 640d
G11 730d
Corasdad
Post Tue Aug 29, 2023 3:17 pm
Depends on the year of the car as to which nu. Bers you put the wire in
Doobit
Post Tue Aug 29, 2023 5:10 pm
Thanks. I've always used the same approach so I know im doing it correctly, its just stopped working now and i think this is because the SI battery needs replacing.
F12 640d
G11 730d
Contours
Post Wed Aug 30, 2023 2:49 pm
The service indicator wont reset if the batteries are done and in my case the rev counter was also out of action. You will be able to identify the batteries once you have the cluster apart and important to put the same type batteries back in. Not a difficult job but you will have to solder in the replacements. Some years ago I brought wire extensions from the terminals inside the cluster to a battery holder outside of the cluster so I never have to remove it to do this job again.
Doobit
Post Wed Aug 30, 2023 4:33 pm
thnaks Mate...think this is what's happened and has been coming for a while. Might make this my winter indoor job!
F12 640d
G11 730d
Contours
Post Fri Sep 01, 2023 7:18 pm
Good, its a job that you have to take your time with. Lots of tutorials on the net about removing the cluster. Make sure you have a towel at hand to protect the cluster glass. Having small hands to remove the plugs at the back of the cluster is an advantage. Take photos anyway to make sure you dont forget the layout of the batteries. On my 316i, the batteries are Varta 1.2volt Nicads but yours may be different. It is nice to have the indicator lights working as the should and a job worth doing.
minesapint
Post Fri Sep 15, 2023 1:07 pm
Removing the cluster is made so much easier if the steering wheel is removed, it’s a five minute job using a 22mm socket, mark the shaft and wheel to realign.
minesapint
Post Fri Sep 15, 2023 1:18 pm
Doing this way makes it a doddle to remove the plugs, no need for small hands this way!
Post Fri Sep 15, 2023 1:55 pm
I know it`s obvious but please leave a few threads on the nut before pulling off the steering wheel as they hurt like hell when it hits your face !!!! :o: :o: :o: :o:
rix313
Post Sat Sep 16, 2023 2:37 pm
You beat me to it Mart :D Top tip!
