Knee panel fixings
Etharla
Tue May 02, 2023 9:29 pm
Good evening all,
I’m having bother keeping the knee panel in place and was looking some guidance. I understood there were only the 3 barbed slotted head fixings on the top of the panel and the base was held in by the slot attached to the steering column!? And the three pronged fitting on the rhs. There’s a hole which looks to be for a fixing in the centre and realoem show there are a couple of fixings but the part numbers are greyed out. I assume these were available at one point but no longer available. Any ideas?
Cheers,
Joe
biffer
Tue May 02, 2023 9:59 pm
1x 51451916579 works for me- it's similar to the 3 fixings at the top of the panel and you turn thru 90 degrees to lock.
Etharla
Tue May 02, 2023 10:35 pm
Thanks for the quick reply. I’ll give that a try.
