Heater loses temperatures at speed
R1cardo
Post Wed Feb 08, 2023 6:26 pm
Heats up fine but loses warmth when you get up o to speed, so above 50ish. Any suggestions?
BenHar
Post Wed Feb 08, 2023 6:34 pm
Thermostat.
Ben
R1cardo
Post Wed Feb 08, 2023 9:47 pm
Thermostats has been replaced
ChrisHC
E30Zone Contributor
Post Fri Feb 10, 2023 5:02 pm
Perhaps the water pump, which is a bit of a weakness on the 6 sylinder cars in my experience.
flybynite
Post Fri Feb 10, 2023 6:41 pm
R1cardo wrote: ↑
What engine?
First thoughts for me, especially if things have been replaced is bleeding? Have you bled the system properly? Nose high, heater set to hot etc etc?
R1cardo
Post Sun Feb 12, 2023 8:55 am
325i. Thermostat was done at a garage, so presumably was bled correctly.
flybynite
Post Sun Feb 12, 2023 10:04 am
R1cardo wrote: ↑
E30 M20s can be a pig to bleed correctly so unless they have experience of E30s then I wouldn't assume anything.
