Oil sump
Corasdad
Need an oil sump I thinks its an m43, numbers are 17152689
flybynite
As I said in your other thread it is an M40 or M42 sump. M43 is E36 and will NOT fit an E30.
Casting numbers are not always the part number. I linked to the correct part number in that other thread.
If it is only the bottom section you need then Febi ones are about £50 new on ebay.
https://www.ebay.co.uk/itm/373067117629 ... BMoMeBpuZg
Can't you get your old one welded up?
Corasdad
But my block is m43, wasn't sure if it's OK to weld
flybynite
Corasdad
Ah I see so my block is m43 but has had different oil sump fitted so that the engine fits, sorry I didn't understand
Thank you
Thank you
Cotswoldbmw
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
