What is this part?
Cooling fan belt broke. Knocked the top cover off this part. What is it? I want to create a replacement cover for it, but may just replace the entire part. But what is it?
- Attachments
“Keep lowering your standards until goals are met.”
- fixedwheelnut
Looks like an atmospheric pressure sensor
Put your chassis number in here and search for the part probably under fuel preparation.
https://www.realoem.com/
- fixedwheelnut
I am thinking part ten here but you need to check against your own chassis number to be sure
https://www.realoem.com/bmw/enUS/showpa ... Id=13_0337
Yes, the base and bracket look similar, but I am not 100% certain. I like the website a lot! Very useful! In the morning I am going to get a look at the underside of it. Hopefully the electronic fitting will confirm. Thank you for your help!
- Attachments
