central locking water damage
Corasdad
Thu Mar 10, 2022 8:36 pm
I got my central locking work but then washed the car and the locking stopped working i pulled it apart again and the relay module was swimming ,its now dried out but still not working, if i press the brass things one locks the car open opens works great so i know my locking work so i am thing my relay is fried,is there a fix for this or is it a new board?
BenHar
Fri Mar 11, 2022 7:32 pm
First thing to do is clear the sill drain holes so that it doesn't get flooded again.
Take the module out and open the casing. Dry it out.
It may be fine.
Ben
V8turd
Sat Mar 12, 2022 6:22 pm
Might be worth bagging it up aswel incase of future water ingress.
It's a stupid place for bmw to have put it in the first place to be honest
ChrisHC
E30Zone Contributor
Thu Mar 17, 2022 2:25 am
Have you checked the thermal cut-out in the central locking relay? It has a strip of metal held to a connector by low melting point solder, if it gets too hot the solder melts and it springs away. Do not use standard solder on it, there is probably enough of the original solder remaining to use again. There is a picture in the wiki.
Corasdad
Tue Mar 22, 2022 8:29 pm
yeah tried that
Corasdad
Sun Apr 10, 2022 3:26 pm
so my car locks and unlocks when i manually press the copper switches on the module one lock the other unlocks,
IO can lock all the doors via the boot or drivers door but nothing opens all the doors, If i use the boot lock it only opens the boot and same with both doors
can anybody shed any light on my issue as i am tearing my hair out
Corasdad
Sun Apr 10, 2022 3:33 pm
to me its like there is no signal for unlocking
Corasdad
Thu Jul 21, 2022 7:16 pm
Got a new/used central locking module and I am still having same issue car will lock but won't open, if I had hair I would be tearing it out
