E30 not starting
riber3
Post Tue Mar 08, 2022 9:36 am
Hi everyone
My car has sadly died on me and although I have gone through some checks I haven't yet found the route of the problem and would be grateful if anyone could point me in the right direction.
Basically car was running fine and then it suddenly died on me and won't start.
Because I couldn't hear the fuel pumps firing up I thought perhaps a blown fuse or a dodgy relay. I can hear the relay clicking in and then straight out again> I have checked fuse 11 and I have tried a jump wire from 87b to 30 and 87 to 30 but still nothing from the pumps.
I have checked the wiring on the pump inside the car and resistance on the pump is fine. I haven't yet checked the one under the car but will try later.
The relay is a 7pin SIEMENS 5WK2221 relay that's what's written on the side. The car is fitted with I think with the L-Jetronic system and I do have spark at the plugs.
I am following through on the sites flowchart but any extra advice or pointers would be most welcome. Many thanks
Blanca
Post Tue Mar 08, 2022 10:24 am
There is is no primer on the pump when switching on ignition, it only runs with the engine turning..
12v across the pump terminals or short the relay connections in the fuse box will prove if the pump works and will also prime the injector rail so it should start.
I take it you have pulled a plug cap and see if t here is a spark?
Check crank position sensor.
Fuel plus spark should equal running.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
riber3
Post Tue Mar 08, 2022 11:12 am
Thanks for your reply which relay do you mean in the fuse box? and yes I do have spark
Blanca
Post Tue Mar 08, 2022 11:27 am
The fuel pump relay is not in the main fuse box depends on the model.
I just belted the pump under the rear left and it worked, turned out to be crap connections on the terminals.
riber3
Post Tue Mar 08, 2022 1:20 pm
That was lucky!!! hopefully you can clean them up and it will carry on running
Blanca
Post Sat Mar 19, 2022 2:33 pm
Just got a delivery from Amazon, a new pump. had to belt the old one again Tuesday so as they are not that expensive a new one was ordered straight away.
riber3
Post Sat Mar 19, 2022 2:53 pm
Blanca wrote: ↑
Well done I have ordered one from ebay not too bad but I am struggling to find a 7 pin relay.
I was trying to find what book and page this post relates to so I can retest my relay here's a link
http://www.bimmerboard.com/forums/posts/1052466
