Hi,
I'm looking to ID a part that goes between the headlight adjusting cylinder and the headlight.
Mines is broken and I wonder if there still availible from the dealer. I've attached pics below.
Headlight part ID
Binkerment
Cloggy Saint
Binkerment
Possibly. I know its broken and someone has screwed it to the headlamp. I'll need to remove the other side to see what's fitted to that side.Cloggy Saint wrote: ↑Wed Mar 02, 2022 9:48 pmThat doesn't look like the original part, more of a DIY bodge.
Any idea what that part should look like?
Cloggy Saint
I could be wrong, but are these the parts? https://www.aliexpress.com/item/32658868618.html
Binkerment
Theyre some of the parts that go round the headlamp. I think the one that connects the adjuster rod to the lamp my be different. I could be wrong. Once I'm back home I'll strip the other side for a look. Probably the easiest wayCloggy Saint wrote: ↑Wed Mar 02, 2022 10:19 pmI could be wrong, but are these the parts? https://www.aliexpress.com/item/32658868618.html
BenHar
Cloggy Saint
Isn't that the same part that I pictured?
Binkerment
Yeah they are. The headlamp has either 2 or3 of those that hold it to the mount. I think they're on the main beam lamp. On the headlight lamp there's the plastic if added pictures of that join the hydraulic adjuster rod to the lamp
BenHar
No.
https://www.schmiedmann.com/en/product/ ... -1-386-616
There is one of this type for the end of the adjuster rod and two of the other type.
Ben
Binkerment
Well I stripped the other headlight off ans the part on that is different. Looks like someone has fitted a random part, which kinda does the trick. I extended the plastic using bonding and modified it slightly and I have the headlight aim almost spot on now. It'll do as a temp fix to get it through the mot until I source the correct parts
