Various parts...
Phid
Post Fri Feb 18, 2022 1:32 pm
Clearance of what I believe to be mostly M20B25 parts. Happy to sell individually or £250 for the lot (based on everything below). Postage will need to be added or collect from near Wimborne in Dorset.
⁃ Air flow meter with regulating valve £60 (I have a second valve £10)
⁃ Rocker cover £60
⁃ Gearbox mount £20 (not sure which model)
⁃ Exhaust manifold gasket/heat shield £10
⁃ Engine mounts £20
⁃ Rocker arm shaft £20
⁃ Viscous fan £10
⁃ Airbox £20 (not sure which model)
⁃ Throttle cable £20 (E46 M52 - see part no)
⁃ Fog light blanking plates £15
⁃ Steering column knuckle joint £30
⁃ Radiator top bracket £20
⁃ 2 x 20mm wheel spacers £15
Photos to follow. Additional pictures available if needed.
Probably easier to text me if interested: 07565 681765 Philip.
Phid
Post Fri Feb 18, 2022 1:33 pm
Phid
Post Fri Feb 18, 2022 1:35 pm
more pictures
