afternoon folks.
hoping someone can help.
just put a new battery on my sport & when i turned the ignition on all the lights on the overhead check panel lit up & started to flicker.
even when the engine was running they stayed lit & flickered.
anyone had this before? or knows what could be the cause & how to fix it?
check panel problems
steve_k
BenHar
If all you did was change the battery then I don't know what could cause that, sorry.
Ben
Ben
steve_k
no worries ben that fine,
i'll sus it.
fixedwheelnut
Get a voltmeter and see what voltage the car is running at when on, it sounds like it might be overcharging like a Voltage Regulator fault.
steve_k
I'll do that in the next few days,fixedwheelnut wrote: ↑Thu Nov 18, 2021 8:08 pmGet a voltmeter and see what voltage the car is running at when on, it sounds like it might be overcharging like a Voltage Regulator fault.
