m20 maintenance
onthames
Post Wed Oct 20, 2021 11:15 am
Currently doing the sump gasket and rocker cover gasket and spark plugs and was wondering if theres anything else i should do/replace while I'm here?
steve_k
Post Wed Oct 20, 2021 12:05 pm
i'd do the dizzy cap, rotor arm, plug leads,
tha881
Post Wed Oct 20, 2021 2:01 pm
Valve clearances usually if the valve cover is off. There are a lot of service jobs on the m20, it all depends how far you want to go, if it's running nicely don't worry too much, just keep doing your oil and filter changes, and cambelt when it is due.
tha881
Post Wed Oct 20, 2021 2:02 pm
Dizzy and rotor definitely worth the effort if they are still the originals, the plug leads usually dont give trouble, and can be checked with a multimeter test
Post Wed Oct 20, 2021 4:51 pm
I do both my cars twice a year for the cost of oil and filters it`s a must for me.
I bought 20 lts of Shell (cant remember now) for @£75 and will nearly do both twice.
paultv
Post Thu Oct 21, 2021 7:05 am
Make sure the spray bar is totally clear. Breather hose from cover to inlet,.. just replace it if its old.
Are the half moon rubbers good? If hard they may well leak after being disturbed.
Then there's the oil pump if you have the bottom off....it just goes on !!
All I'd say is leave alone things that are fine !!
Paul :-)
