PROBLEM AFTER LOWERED!!
BarateGites
Post Sun Aug 29, 2021 10:38 pm
Hi Guys
i lowered my bmw e30 cab last week with eiback pro springs and bilstein b4 suspension by 30mm. since ive lowered the car my driver side rear tyre is grinding against the tyre. it currently has 205 tyres and ive been told to get 195 now. anybody else have this problem?https://omegle.onl/ vshare
paultv
Post Tue Aug 31, 2021 7:54 am
If your car is RHD check the plastic flap which covers the fuel breather pipes is correctly fitted, it's common for a mount to be missing which makes it hang low and scrape on the tyre especially when cornering.
Paul :-)
Kedge
Post Wed Sep 01, 2021 11:13 am
No way you should be needing to fit smaller tyres on a 30mm drop, that's assuming you're talking about 205/55/15s.
Instagram - Kedge85
