Cps replacement
JinstKebe
Post Sat Aug 14, 2021 5:30 pm
Just did a timing belt replacement on my 1988 e30 and when trying to start it it would crank but not start. New battery, plugs, coil, distributer. checked the plugs to see if they were fouled but they looked fine. New fuel regulator and fuel filter. I've read the culprit can often be a bad cps since I had literally just driven the car into my garage this morning and noticed hot coolant spill all over the sensor when I was removing the water pump. curious if that maybe screwed it up.
Anyways, is it recommended going oem with these things or seeing if anyone has had any luck with aftermarket ones?
Much appreciate.https://omegle.onl/ vshare
steve_k
Post Sat Aug 14, 2021 6:05 pm
first things first, what engine is it?
