M10 rebuild or swap
ShawHale
My engine in my 318 is blown. It's the m10 engine. I basically have three options, do a full rebuild on the m10, swap in an m20, or swap in an m52. The m10 is as bad as they say it is but if it's a lot easier and cheaper than I'll just stick with it. Which option should I go for? How much would an m20 swap cost? Thankshttps://omegle.onl/ vshare
What has "blown" in your engine as the M10 is virtually indestructible ?, is it the carb or injected version ?
As to what to do with it ..............well that depends on what your intentions for it are as in need for more power etc ?
The m50/52 is a good swap but brakes ,drive train and suspension etc will all have to be looked at too.
(moved it to e30 bmw chat for more coverage)
Fixing an M10 will be a hell of a lot cheaper and easier than an engine conversion, especially if you are paying for all the labour
