Getrag 240 and m52
JohnA
Tue Jun 15, 2021 2:51 pm
Hi all,
I'm planning on doing a m52 swap in my 318 convertible ( currently running a m42 engine ) and i'm putting together a parts list.
I'ts probably been answered before :? , but my online search gave me all sort of different answers on the gearbox compatability... so I thought i will ask the experts
so:
Will the getrag 240 from my 318i mate up with a m52?
or will i need to find a G240/260 coming from an m20 ( and change the propshaft? )
I was hoping it does, so i only have to change the rear differential. ( i was looking at a small 3.6 ratio diff )
Here's a picture, just to make shure we are talking about the right car: :wink:
JungleGus
Tue Jun 15, 2021 4:40 pm
As far as I understand - it will work and not need to be rotated at all - but I am not sure of longevity, especially with the clutch.
If you had a g260 from a 325i M20 then I'd suggest just getting the twisted shift linkage and gearbox mounting bracket, but the right way to do it since you're changing everything would probably be the M52 ZF box, propshaft and diff....
Keeping the M42 may be easier =D
JohnA
Wed Jun 16, 2021 2:07 pm
thanks Gus
yes, keeping the m42 would be easier, bet hey, we do things not because they are easy, but because they are hard, because that goal will serve to organize and measure the best of our energies and skills, because that challenge is one that we are willing to accept, one we are unwilling to postpone, and one which we intend to win. Or so i heard.
and, also i think a 6 cyl would better fit the heavier convertible, and make for a nicer cruiser.
Wed Jun 16, 2021 2:48 pm
I think/hope Gus meant keep the M42 gearbox, even though its most likely a 318i box :)
It will bolt straight on and be in the correct position, you will need a 325i propshaft and the linkages will need some cutting/welding or see what fits, 320i stuff is close from memory
Ive done quite a few conversions with the 4cyl box's and they hold up quite well :D
JungleGus
Wed Jun 16, 2021 3:23 pm
Great JFK quote! And yes, I don't blame you for going that path...certainly a bit tougher now than it was 5-10 years back
JohnA
Thu Jun 17, 2021 8:13 am
It is indeed a M40 box, not the M42 one, I should have been more clear.
so, if I got this right, even with the M40 gearbox, I will need a different propshaft? This means it is not in the same place as it is now obviously...
As for longevety, a 260 will be stronger, but I'm not building a track day car here, more a weekend cruiser, so should be fine ( what could go wrong, it only has 200k miles :) )
sourcing a propshaft is no real problem, as for now all is still quite availably i think.
thanks for your input
Thu Jun 17, 2021 8:52 am
If you look at the position of the back edge of your current engine and compare it with an M52 converted car you will see the 4cyl is further forward so a shorter prop will usually be needed
Andyboy
Alpina Colada
Fri Jun 18, 2021 1:10 pm
Or you can pay me a load of money for my M50 E34 Getrag 260. Bolts to the M52 with a 325i prop and gear linkage.
viewtopic.php?f=6&t=281459
chilone
Fri Oct 29, 2021 10:53 pm
I am wondering the same thing (sort of). I'm putting an M50 in a 1991 318is. It has a Getrag 240 in it. Won't the M50 just bolt up to the 240 without having to do anything to the driveshaft, as it is the stock gearbox?
Be30
Sat Oct 30, 2021 1:31 am
Bolts up pretty well to a 240
You’ll want a 320i prop though if i remember right
aimlessrock
Sat Oct 30, 2021 5:00 pm
thats a nice looking cabby and in a nice colour. Its clearly been looked after.
I have a 320I cabby - the 318i is just as able but less thirsty.
its your car at the end of the day but unless the conversion works are done by a reputable person/company it will likely only devalue the car and make it difficult to insure.- have you also checked the local regs (i have assumed as the car in on French plates your in France).
why not keep the car stock and buy something modern to smoke around in - plenty of modern turds floating around.
E30 320i Convertible (1989)
190 Mercedes (1988)
