Power Steering - M10
LastRideHome
I’m looking for a full power steering setup for an m10 engine (pump, pulley, reservoir, lines and rack). Subsequently, does anyone know if PAS parts from an m40 are compatible with an m10? I figure the brackets would be different but those can always be fabricated. Thanks.
PM Magpie or Sweep on here , maybe Brutus as wellLastRideHome wrote: ↑Mon Jun 14, 2021 6:09 pmI’m looking for a full power steering setup for an m10 engine (pump, pulley, reservoir, lines and rack). Subsequently, doesn’t anyone know if PAS parts from an m40 are compatible with an m10? I figure the brackets would be different but those can always be fabricated. Thanks.
LastRideHome
Thanks, will do.martauto wrote: ↑Tue Jun 15, 2021 5:41 pmPM Magpie or Sweep on here , maybe Brutus as wellLastRideHome wrote: ↑Mon Jun 14, 2021 6:09 pmI’m looking for a full power steering setup for an m10 engine (pump, pulley, reservoir, lines and rack). Subsequently, doesn’t anyone know if PAS parts from an m40 are compatible with an m10? I figure the brackets would be different but those can always be fabricated. Thanks.![]()
