M20B25 Service Items
Vez010
Post Wed Jun 02, 2021 4:19 pm
Hi, I’ve just had a read through the wiki but not been able to find a breakdown of what products are recommended for servicing an M20B25 engine.
Appreciate it if some of the more experienced owners can share what their go to products are for the following:
- Oil
- Spark Plugs
- Coolant
- PAS Fluid
- Brake Fluid
Thanks in advance.
paultv
Post Wed Jun 02, 2021 6:24 pm
Always check the condition of the distributor cap and rotor....if its worn, pitted which it will be...replace it, it's night and day when you fit a new one ...of course you can clean the posts and file them clean as with the rotor but this increases depressions making the spark jump further causing increased pitting.
Paul :-)
Vez010
Post Thu Jun 03, 2021 10:13 am
Cheers Paul will look into that. Any recommendations for which spark plugs, oil, coolant etc which I should use?
Tzantushka
Post Thu Jun 03, 2021 12:03 pm
Have a look in the Wiki as most recommendations are in there
e.g. spark plugs -> https://www.e30zone.net/e30wiki/index.php/Ignition
With Oil, be prepared for lots of opinions for lots of climates for lots of driving conditions - oh yes... and lots of change intervals.
Best to stick with what's in the manual for oil grade.
But look for an oil with a high anti-wear additive (e.g. Zinc commonly a ZDDP additive)
I'm in Australia so can only give you suggestions for our country.
For coolant, BMW (blue) coolant is proven.
Vez010
Post Thu Jun 03, 2021 2:37 pm
Thanks. I did have a look at the wiki before I posted but thought I’d ask for a more updated opinion.
Thanks again.
Lemon98
Post Sun Jun 06, 2021 5:50 pm
For coolant I use Comma xStream G48 and a 5w40 engine oil. I've used Millers CFS and Fuchs Titan Race Pro S & live in the south east and took the car out in the snow to drift earlier this year with no problems. I have replaced the oil twice in the year and a bit that I've owned the car purely as a 'might as well while i'm here' with other servicing.
For plugs I use NGK ZGR5A (5839)
Comma Power Steering Fluid and Conditioner is what I used earlier this year to replace mine.
With brake fluid it depends what your requirements/preference is. A good DOT 4 from any name brand will be fine but you can get super DOT 4 if you want a higher boiling point. MOTUL RBF is high quality or ATE typ 200.
For the distributor cap and rotor arm DO NOT buy the BREMI cap from autodoc, it's black cover is a terrible fit (doesn't clear the metal coolant pipe properly) or the Bosch ignition leads unless you're willing to take the plastic cover off because the leads aren't numbered.
I have an M20B20 but those service parts should be the same.
PS Don't forget to check your valve clearances!
Enjoy and take your time with things and getting to know your E30 :)
1990 4-door 320i SE
Vez010
Post Tue Jun 08, 2021 12:40 pm
Lemon98 wrote: ↑
Thanks very much!
