Overheating problems
Be30
Post Wed May 12, 2021 7:52 pm
Evening
Okayyy, i have an issue with an m52 swapped touring at the moment and i think i know whats causing it but would just like some confirmation/ other ideas about what it could be!
Its overheating basically, but its odd in the way that i can bleed the entire system, have hot air in the cabin etc and leave it running for 20 minutes without an issue. But then if i go back the next day and start it, it will heat up much quicker than normal, no hot air in the cabin and start to over heat at which point i switch it off again.
Its like its de-bleeding itself over night (if thats a word) and drawing in air causing an air lock which would explain the lack of hot air through the blowers? Would this point to some sort of coolant leak? The coolant level doesnt seem to be dropping at all, by looking into the rad at least
Hope someone knows what they’re talking about
BristolE30
Post Sat May 15, 2021 11:52 pm
The system is pressurised meaning the water inside wants to leak out, hence why you get leaks. I don’t think it would be possible for a leak to somehow incorporate air into the system due to the pressure forcing water out, rather than anything in. The unfortunate alternative which is likely your case is a leaking head gasket, allowing combustion gases to leak into your water jackets and cooling system.
Buy a sniff test or take to a garage to confirm
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
BristolE30
Post Sat May 15, 2021 11:53 pm
Either that or it’s just not bled properly
BMW E30 316 ‘87
Bristol, UK
Be30
Post Sun May 16, 2021 11:28 am
Yep! As suggested i hadnt been bleeding it properly :roll:
Runs lovely now ive done it the right way!
BristolE30
Post Mon May 17, 2021 11:41 pm
Nice one!
BMW E30 316 ‘87
Bristol, UK
Post Tue May 18, 2021 11:11 am
Goes into negative pressure (relative to atmos.) when the system cools down, so not totally impossible.
BristolE30
Post Tue May 18, 2021 2:04 pm
I guess it wouldn't be circulating though, so not much draw in..
BMW E30 316 ‘87
Bristol, UK
