Hello,
I have a finalised parts list for my BMW M3. I have included the car details, amount required and parts numbers (some I could not work out) below.
If you think I have missed anything that would make sense to change could you please advise.
BMW E36 M3 EVO 3.2
M300CRB
WBDBG92070EA89005
Engine oil filter (1) - 11427833769
Oil Filter O-ring (1) - 11421741000
Pollen filter (1) - 64119069895
Water pump (1) - 11511405720
Water pump gasket (1) - 11511318287
Water pump dowel pins (2)- 07119942283
Water pump bolts (3) - 07119904589
Water pump bolts (3) - 07119912360
Water pump wave washer (9) - 07119912360
Water pump pulley (1) - 11511401154
Water pump pulley bolts (4) - 07119904517
Fan 11 blade (1) - 11521712058
Fan clutch (1) - 11527505302
Fan ISA Screw (4) - 07129905536
Thermostat (1) - 11531318274
Thermostat O-Ring (1) - 11531318402
Thermostat bolts (3) - 07119912364
Thermostat pipe (1) - 11531317587
Thermostat O-Ring (2) - 11531317588
Hex bolt (1) - 07119913420
Water hose (1) - 11531317394
Water hose (1) - 11531401726
Water hose (1) - 11531405580/11531401729***
Water hose (1) - 11531317589
Water hose (1) - 11531405581
Water hose connection (1) - 11531318404
Vacuum non return valve (1) - 11611312737
Rocker cover gasket (1) - 11121404358
Rocker cover gasket (2) - 11121402637
Fan belt (1) - 11287636366
A/C belt - ***
Fuel filter (1) - 13321405092
Power steering reservoir (1) - 32416851217
Power steering pipe inlet (1) - 32411138419
Power steering pipe return (1) - 32412229001
Track rod left (1) - 32111139315
Track rod right (1) - 32111139316
Self-locking nut (2)- 32216756327
Rubber boot (2) - 32211139786
Rubber column bush - ***
Rear diff input seal (1) - 33121213949
Rear diff output seal (x2) - 33107510289
Rear diff gasket (1) - 33108305033
Rear boot seal (1) - 51718171244
Splitter fixing (7) - 51112252200
Splitter fixing (7) - 07419126885
Splitter fixing (4) - 51111908077
*** - not sure on part number
Many thanks
E36 M3 evo parts
Cotswoldbmw
Thank you for your enquiry, the cost to supply the items required will be £1968.11, however part numbers 07119912360 and 07119912360 are no longer available.
Please check that part number32311159763 is the correct rubber column bush you didn't have a part number for.
PM us you email address if you want a detailed price breakdown. Please make sure you include the quote ref no.
This price is valid for 7 days from today.
YOUR CUSTOMER ORDER REFERENCE NUMBER IS – P45491
Payment Options:
For orders between £250 and £5000 we are able to offer 0% finance over 4 to 6 months.
To find out more information on our finance offer please email us directly on partscheltenham@cotswoldgroup.com with your reference number and preferred payment plan.
For orders under £250.00
Payment by card - Please call 01242 335365 with your card details and customer reference number, please note the delivery address must be the same as the address the card is registered at.
Payment by PayPal – Please send the payment to partscheltenham@cotswoldgroup.com
Quoting your customer reference and your delivery address.
For orders over £250.00 we will only accept bank transfer.
Cotswold Motor Group Ltd
Bank: Barclays, One Snow Hill, Snow Hill Queensway, Birmingham B4 6GB
Bank Account: 40292230
Sort Code: 20-07-71
Please include your customer reference in the notes section but please call or email us with your delivery address.
PLEASE PROVIDE US WITH YOUR VEHICLE REGISTRATION OR CHASSIS NUMBER TO SECURE YOUR 2 YEAR MANUFACTURERS WARRANTY
For GDPR purposes please confirm if email is your preferred method of contact for any future communication or marketing from Cotswold. (We do not share your data with any 3rd parties)
CLICK HERE TO SEE OUR ACCESSORIES BROCHURES
Regards,
Mark
Payment Options:
Sort Code: 20-07-71
Regards,
Mark
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
