Hi,
Could you check the prices for these parts please and provide itemised costs?
The car is a 1989 E30 325i Sport, manual without AC. I will PM the reg and VIN number shortly.
1. Radiator fan shroud (standard 440mm width radiator): 17111712846
2. Radiator top hose: 11531722216 (I think?)
3. Clutch fluid res lid: 17111712846
4. Gearknob and gaitor - I believe my car should have a one piece unit? What options are available please?
5. Gear linkage refurb bits, these are the part numbers from RealOEM so hopefully correct with quantities required shown.
Gearshift rod joint: 1x 25117503525
Dowel pin: 1x 23411466134
Tension bush: 1x 25111203682
Plastic washer: 1x 25111434194
Shift lever bearing: 1 x 25111220600
Spacer ring : 4 x 25111220439
Circlips: 2 x 25117571899
Much appreciated!
Stu
Quote please - cooling parts, clutch res lid, gear knob and linkage bits
Cotswoldbmw
Hi there, I have responded via PM
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Cotswoldbmw
Cotswold BMW Parts
01242 335365
01242 335365
