lumpy idle until motor is at temp
colin325ix
Hi< i have a 325ix 5 speed M20 and I am having a issue with when i cold start the car. I start it and the idle is very lumpy almost sounds like it has a cam roll, this lasts for about a minute when its cold out. I have checked for vacuum leaks already. Today, i pulled the harness off the ICV and it stopped lump idle. any ideas???
Hi Colin and firstly welcome to the zone mate !!!colin325ix wrote: ↑Fri Feb 26, 2021 12:38 amHi< i have a 325ix 5 speed M20 and I am having a issue with when i cold start the car. I start it and the idle is very lumpy almost sounds like it has a cam roll, this lasts for about a minute when its cold out. I have checked for vacuum leaks already. Today, i pulled the harness off the ICV and it stopped lump idle. any ideas???
You are in the right place for an answer and I`m sure some bright spark will come along and try to help.
Where are you based and lets have tons of pics of your 325ix please ???
steve_k
first thing i'd try is to clean the ICV out, remove it, spray a liberal dose of carb cleaner in it & the roll it back & forth between your hands till it rattles,
place it back in the motor, start it & see if its still the same or improved.
