Just removed my inlet manifold and need the following parts delivered to ig3 9jx
Have attached the pictures. The stud is the longest one out of the 12 which are needed
Regards
Yaad
Parts needed
yaad
handpaper
I very much doubt you'll be able to buy one of these used, but you should be able to order one from your local dealer.
Part number is 07 12 9 908 142 .
Failing that, it's a 70mm M8 stud, just buy some M8 threaded bar and cut it to length.
Cloggy Saint
