I was hoping to spend my Saturday swapping over the radio in my 318i.
This started with removing the Blaupunkt Porto 26 (Looks basically Identical to the Stockholm R 26 without the LD button.
Once that was out I notice one thing. the previous owner must have been Edward Scissorhands, as all the cables had been chopped and changed and re-attached. I am looking to swap in a Continental TRD7412UB-OR, which seems to have quite a different connection profile.
These are the cables I have available to me, coming out of the loom (they were originally connected to the Blaupunkt Porto 26).
From L -> R::
White cable: Antenna Switch I believe. Fits to the terminal next to the +ve and Ground terminal.
Brown+Red Pair: Ground and +ve cables
Black+Red(x2): These are Left and Right speaker cables.
Black(With Electrical tape): FM Radio Cable.
I am also going to install the DAB antenna but that seems like a non-issue compared to actually getting the new radio connected. I understand that the radio antenna goes into the antenna socket, but seeing as I only have one L+R cable, and the new radio has LF,LR,RF,RR connections, so I am unsure what to do. I am confused as to where the white cable should end up, as I am assuming that controls the aerial extension.
If anyone could help me work out what it is I need to do to get the Continental connected, it would be greatly appreciated.
