Fuel pump.
jmec
Post Fri Jan 15, 2021 2:30 pm
Hi, 1990 325i. The fuel pump is pressure is 2.5 bar. I understand it should be 3 bar. On removal I can see very fine pieces of debris. Shiny, non ferrous. I'm guessing it's an aluminium impeller. Question is what is a reasonable replacement choice. The interweb comes up with all kinds of make at prices from £24 to £420! Thanks in advance.
reggid
Post Fri Jan 15, 2021 11:03 pm
depends how long you intend to keep the car, a genuine or VDO one will last a good while and therefore may make sense even if spendy while cheap ones wont and should be avoided. there are some good aftermrket brands but depends what brands you have access to.
make sure the tank is clean
also FPR could be a culprit if yu havent checked that
E30 325is with M20B31
jmec
Post Sat Jan 16, 2021 12:19 pm
I replaced the FPR a short time ago because it failed on the pressure check carried out following the Bentley Manual. However the pressures remained low and that prompted a pressure check on the pump. I fitted a tee piece and gauge in line directly to pump outlet. There it indicated 2.5 bar. I've blown through the lines and checked the gauge for accuracy against a known source. As I mentioned there's small traces of non ferrous shiny metal in the tank directly below the pump and tapping the pump when removed revealed more traces. It's a VDO unit. There's no shortage of pumps available and an array of good makes. There is a selection of Bosch replacements for instance. Ranging from mid £70s to £150 ++. Just wondering if anyone has similar experience and have fitted a pump they're happy with.
Post Sat Jan 16, 2021 2:08 pm
You are making a fundamental mistake with your understanding of fuel pressure. The FP, as written on the regulator, is the pressure difference between the fuel in the injector rail and the inside of the inlet plenum. A gauge measures the difference between the rail fuel pressure and atmosphere, which will be around 0.4 bar or so lower when the engine is idling.
It's very rare for a E30 fuel pump to fail just giving insufficient pressure. It's usually either wear in the gears, causing them to jam, or the motor commutator completely wearing away.
jmec
Post Sat Jan 16, 2021 2:51 pm
Now that's interesting Brian. I get what you're saying. Was my understanding of the Bentley FPR flawed because it mentions fitting the pressure gauge to the shraider valve at the end of the injection rail. My car hasn't got that facility so I fitted the gauge in line to the rail feed?
BenHar
Post Sat Jan 16, 2021 5:01 pm
I think the point Brian is making is that 2.5 bar is fine.
Ben
Post Sat Jan 16, 2021 7:41 pm
Never seen a shraeder valve on a E30 fuel rail yet, unless it has a M5x engine. The Bentley manual seems to be considered the gold standard, but I've never been particularly impressed with it.
Disconnect the small reference hose to the FPR and you should see nearer 3.0 bar on your gauge.
jmec
Post Sun Jan 17, 2021 9:39 am
Thanks again Brian. I'll view the Bentley Manual with less reverence in future!
Blanca
Post Sun Jan 17, 2021 3:04 pm
If you have to referee to a Haynes manual you really are in trouble. Bentleys we don't have here. Datacar, yes.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
