Blue temp sensor ground located?
NoTurbo
Sun Nov 22, 2020 1:13 pm
Hi guys, I just changed a broken plug on my blue temp sensor and am trying to trace the wires back to the Ecu.
None of the pin out diagrams I have show where the blue temp sensor is grounded.
I have 400+ ohms when cold across the sensor and continuity from + terminal to pin 78.
Just can't find the ecu pin for the - ve side.
Any help would be great.
NoTurbo
Sun Nov 22, 2020 1:18 pm
Scratch that, found it. Across pin 43
rix313
Sat Nov 28, 2020 8:38 am
There is a really good ECU diagram I used for my ECU swap. Did I send it to you before? If not I'll dig it out and see if I can post it or send it ober.
