e30 M3 front bumper ??
Would you be able to modify a e30 m3 front bumper to fit a e30 325i ?? and if so is it alot of work ? or could any half decent bodyshop fit it ? many many thanks in advance.
- Kos
- Contact:
it possible and not too much agro,if its a post 88 car you need early spec front pannel and bumber irons, and the bumper will bolt straigh on, the only thing you will need to mod is the corners of the bumper, just pull them in a bit to sit flush with the wing.
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
wrong!maxfield wrote:No its not possible unless you got wide arches like the M3
look above
IG Pukar.Designs
IG Pukar.Designs
