Hi folks
in the middle of a full strip and rebuild project and have bought some Epytec rear towers to replace the standard ones
https://epytec.de/en/chassis/body-reinf ... rut-mounts
does anyone have any experience with these or any shock tower replacement of any kind. The new ones match fairly well to the inner arches etc but not perfect and will no doubt require some fettling. Thoughts were to bolt the new to the old holes then tack in place then chop out the old ones from the wheel side. Currently thats not possible due to metalwork clashes.
Obvious concerns are misalignment of the new towers compared to standard etc
any advice greatly recieved
Chris
Rear shock tower reinforcement
There are so many reinforcement myths out there people get obsessed with it, 99% are a waste of time and money, unless your towers are falling apart with rust I wouldn't be chopping them out for the sake of it
The only way to fit them in the correct place is to make a removable die/brace that fits the bolt holes and angle of the top plate, so once you have cut the old panel out this can be bolted back in to position the new panel
ceige85
No worries, i was suspecting that would be the best way to do it. Not in the worst condition but just being picky i guess. My roof however has some questionable sections to it from the old sunroof tray so thoughts are to get a roof from you guys
Chris
Chris
Agree with Dan re E30 rear towers, unless you are fitting genuine coil overs, but the same supplier are offering these : https://epytec.de/en/chassis/camber-adj ... adjustment as a cheaper and simpler solution to the camber problem, compared to the more work and cost intensive 5 series eccentric bolt solution, although it does just look like someone has attacked a couple of bolts with a grinder.
ceige85
Afraid i am indeed going full coilovers (gaz gold). Im balls deep in the build at the moment so doing this extra piece so i never have to look at it again is the frame of mind i guess. Seeing this as a small job compared to potentially removing the entire rear end of the car to fix the utterly cr@p job someone did on the rear panel before me. You can guess im slightly ocd but most engineers are
Even with these, the towers should be strong enough, but, at this level, you'd normally pick the mounting points up on the roll cage.
