Steering linkage guibo.
E30Fitz
Fri Sep 25, 2020 10:25 am
Hi, does anyone know where I can get a solid linkage guibo, like the one pictured in the wiki pages picture. Regards Scott.
Satan
Fri Sep 25, 2020 2:56 pm
Post a link up to the photo, if it's the bit from the steering wheel I bought one from DanThe a few years back you have to send your old one back though.
Not solid has the rubber bit in the middle so I may be talking out of my backside and on the wrong end of things....... ;o))))))
Sat Sep 26, 2020 9:05 am
Have a look here if you are on facefook
E30Fitz
Sun Sep 27, 2020 5:51 pm
Thanks dan, I'll have a look.
964russ
Thu Oct 08, 2020 6:16 am
I fitted a corsa 1.
Solid, no rubber bit. £15
Thu Oct 08, 2020 8:05 am
I remove lots of corsa linkages from E30's that are falling apart, mine are a no faff straight forward fit, made from brand new custom made parts
Satan
Thu Oct 08, 2020 1:34 pm
Buy from DanThe support a respected zoner and support the Zone, buy cheap buy twice.
Acaciastrain360
Sat Oct 10, 2020 7:35 pm
Yeah I get it, but Jesus from £220 wtf man
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
Satan
Sun Oct 11, 2020 4:10 pm
It means you don't love your E30.......... tsk ;o)))))
Dlb26
Sun Oct 11, 2020 4:55 pm
Ha, guilt trip him into it :clap: :clap:
Are you on commission with DanThe? winkeye winkeye
Satan
Tue Oct 13, 2020 6:57 pm
Lol, I wished........ :clap: :D
HJ1981
Thu Oct 15, 2020 7:17 pm
I have some every so slight play in my shaft, that price is a lot but since BMW no longer manufactures one.....i wonder if the German TÜV would cause problems for me and if i could slide a rubber guibo in there for vibrations.
Satan
Fri Oct 16, 2020 12:42 pm
Dante refurbs the originals (no Mart I am not on commission) as I bought one from him, you just need to send your old one back.
Fri Oct 16, 2020 2:09 pm
Just to clear things up, I don't do a reconditioning service, I may have sold a good standard one on a part ex basis a few times, I definitely don't do commission :)
You can buy the rubber section new from BMW and fit it yourself with the bolts supplied.
The linkages I make are mainly for conversion purposes, its slimmer and shorter than the original and also has no rubber section, unfortunately some people don't understand the concept of how much new custom parts made in low volume cost to have manufactured, im not going to explain, but I will explain that the reason I now only use brand new parts manufactured by specialists is that I have removed far too many bodged up linkages from E30's that were falling apart, most of them resemble an old corsa part, some had been sold by so called specialists and a small handful had detached from the column while it was driving...
Satan
Fri Oct 16, 2020 2:37 pm
Ahhh good to clear that up, it was a few years back.
HJ1981
Fri Oct 16, 2020 6:04 pm
Thank you for clearing that, i must check with German TÜV first if this is allowed, since it is technically a change to a factory item, BUT it is no longer available and used ones will last only so long before hitting the same issue again. Especially with H-Historic plates that i am keen on getting in Jan.
Satan
Sat Oct 17, 2020 9:17 am
My son got his H plate a year or so back as his is an older model 86 I think we had to swap the lights out for Smiley's as they are adjustable, I think he took it for the test it failed then he sorted out the failures and re did the test.
Where are you located in Germany by the way, I know the profile states Bavaria but which city/town?
Sat Oct 17, 2020 11:16 am
Quick search for the part number reveals the rubber coupling and special bolts are indeed available, upper UJ also available.
https://www.realoem.com/bmw/enUS/showpa ... Id=32_0420
HJ1981
Sat Oct 17, 2020 11:56 am
In Bayern/Bavaria. As i did the TÜV earlier this year, the Prüfer informed me on two issues that he let slide by this time. One was the adjustable headlight function was not working (the sealed/hydraulic ones, not the electric) and the driver's side hand brake was weak while the passenger side was too tight. I am planning on getting the headlights adjuster from Hella and sort out the parking brake/hand brake next week, Jan 2021 i should be able to get H plates.
As far as the steering shaft is concerned, i am unsure what options we have on replacing a bad one which is NLA from BMW.
Satan
Sat Oct 17, 2020 3:48 pm
If you remove the adjusters it should pass,
My son lived in Frankfurt for a few years but moved to a new job in Hamburg a few years back, are you German BTW?
