E30 6 Cylinder Swap Tach Range Instrument Cluster Coding Plug Board - NEW! - SOLD
DUBmekrazy
Wed Sep 02, 2020 6:38 pm
BMW E30 6 Cylinder Swap, 8000 RPM Tach range Instrument Cluster Coding Plug Board
Custom Coding Plug Board for 6 Cylinders Petrol Engines and Instrument Cluster with 8000 RPM Tachometer
This is the Coding Plug Replacement Board
This board is perfect if you want to have correct rev readings on your 8000 rpm instrument cluster/odometer/tachometer if you have a 6 cylinder engine BMW and needed if you've done an engine conversion from a 4 cylinder to a 6 cylinder engine
Fits any 6 cylinder engine e.g. M20, M50, M52, M54 as well S38, S50, S52, S54 etc...
Very easy to swap into your original 4 cylinder coding plug. There's a video on YouTube on how to do it.
I bought it from eBay from a seller in Lithuania, but I no longer need it as it took too long to arrive and sourced an alternative.
Free postage
£25
BMW e30 6 cyl swap, 8000 RPM Tach range Instrument Cluster Coding plug board copy.jpg
