I’ve been searching for a bit in this forum for how much refrigerant to put in my R134A converted A/C system. The wiki says 975g but doesn’t specify whether it’s R12 or R134A... do you put the same amount?
I had my a/c serviced today because it wasn’t as frosty as it used to be. They pulled out 814g and put 400g in because that’s what their system said an E30 on R134A wants.
Now it’s blowing coolish, but doesn’t create the condensation on the outside of the windscreen like it used to.
How much a/c refrigerant?
Radar
E30 M3 Convertible
911 Turbo S
CLS63 Shooting brake
911 Turbo S
flybynite
The 975g is for R12 according to the manual I have
There is only about 15% difference between R12 and R134a (R12 being higher) so I make it about 830g for R134a
The 814g you pulled out is about right.
E30s have a lot more refrigerant than modern cars so putting 800g+ into a small car may have seemed wrong, or they were using figures for a newer 3-series
Radar
Many thanks!flybynite wrote: ↑Tue Aug 11, 2020 9:18 pmThe 975g is for R12 according to the manual I have
E30 M3 Convertible
911 Turbo S
911 Turbo S
Radar
Filled to 830g now. It's better. Good enough for my road trip. Will do further investigation once I get back. It used to be super cold, even in the hottest weather, now it works well enough to be comfortable in 32 ambient with the roof down.flybynite wrote: ↑Tue Aug 11, 2020 9:18 pmThe 975g is for R12 according to the manual I have
E30 M3 Convertible
911 Turbo S
911 Turbo S
flybynite
Is this the first time you have used it with R134a in it?
Radar
No. My car didn’t have A/C as standard. I bought the parts from someone who was building a track car and had it professionally fitted about 4 years ago with parallel flow condenser, new drier and new compressor and so on. It’s never leaked however I have noticed recently that the performance had slipped.
E30 M3 Convertible
911 Turbo S
911 Turbo S
flybynite
Could be the dryer if it has not had much use. Where did you get it recharged? Doesn't sound like I would put much faith in them.
I am assuming VehVac is fairly local to you, if you get no more joy I would give them a ring, they tend to know their stuff
Radar
I’d never heard of them. How did you know they’re in the same town as me?
E30 M3 Convertible
911 Turbo S
911 Turbo S
flybynite
Radar
They look really good... wish I'd found them years ago. I will definitely be seeing them on my return.
E30 M3 Convertible
911 Turbo S
911 Turbo S
